1 - 3 of 3 Posts
I am currently swapping my ej25 non turbo out and while im doing that i have to replace the clutch, the previous owner said it had a stage 2 clutch but its going to need replaced. So can you actually run a stage 2 in your R.S or not? Would you be able to use a wrx clutch kit?
Super Moderator
2000 RSTi
You can run a stage 2 clutch for an RS, and you can also run a 2006+ WRX clutch kit in there.
The WRX clutch kit needs a WRX clutch fork, and minor grinding of the bellhousing to fit. And a 06+ WRX flywheel if that doesn't come in the kit.
1 - 3 of 3 Posts
