I've been searching through STIS wiring diagrams for two days looking for the right harness diagram.
I bought what was advertised as a 2000 RS Engine Harness but some of the wire colors do not correspond with what the diagram says.
What I have found so far:
Crank sensor diag. says pin 1: Black, pin 2: White
I have pin 1: Yellow, pin 2: Orange
IAC diag. says pin 1: Orange-Green, pin 3: Green-Yellow, pin 4: Green, pin 6: Blue-White
I have pin 1: Green-Red, pin 3: Blue-Black, pin 4: Blue, pin 6: Red-White, pins 2&5 match being Yellow
MAP Sensor diag. says pin 1: Black, pin 4: Red
I have pin 1: Green, pin 4: Yellow-Black
TPS diag. says pin 2: Black, pin 3: White
I have pin 2: Green, pin 3: White-Black, pins 4 matches being Red
ECT diag. says pin 2: Black
I have pin 2: Green, pins 1&3 match being Black-Yellow and White Green respectively.
Map sensor diag. says pin 1: Black, pin 4: Red
I have pin 1: Green, pin 4: Yellow-Black and pins 2&3 match being Green-Black and Red respectively.
Any ideas? I've been through years 1999-2004 on the Impreza without a match.....:blol:
Here's pic of the said harness
