Hiya all... kind of a big question for me at least. What's the difference the engines you can replace the stock on with fairly easily. EJ25 etc, hp differences, mod differences.... please post any info that you have... I'm very confused atm hehe.
just to clarify, this is only SOA (subaru of america). in other countries they have different engines. for example, in Israel they have a 1.6 in the current impreza (see my thread in OT for more details).I think Subaru is currently making 3 different sized engines
I meant in the US or SOA.. Som etimes Imay mumbl eand ru nmy wor dstoget her, andfor getto sayso mething. Than ksfork eep ingme in chizeck.10th Warrior said:
as far as swaps go, the big on is sourcing a J-spec EJ20 out of a wrecked STi and swapping it and its computer etc. good luck finding pump gas to run in it though.
Housing???? Huh? Do you want to swap out internals (rods and pistons)?DragonRM said:Just wondering differences in the engines available that fits in the rs housing. I don't know entirely what to ask and that's why I'm asking for any infoI'm not necessarily planning to do it but was curious
Why wouldn't 93 be enough? Japanese spec calls for 100 RON minimum. UK spec, most likely what we will see, calls for 95 RON minimum... Our 93 (RON+MON/2) = 98 RON.as far as swaps go, the big on is sourcing a J-spec EJ20 out of a wrecked STi and swapping it and its computer etc. good luck finding pump gas to run in it though.
Here's a dumb question.... I plan on running Templar's SC kit too... even though he's designing it with stock in mind... I wonder about the wear and tear on gaskets even at 6psi. My car is fairly new, I'd rather take preventive action than repair the thing.zoinkssooby said:quote froom Matrix Engineering: if you turbo or s/c the ej25 definately swap your heads or at least the valve springs for anything over 8psi. not only that but, do your gaskets as well.
I did ask why and they told me that because of the compression ratio being 11:1 you WILL blow your gaskets if not ruin the engine all together. the only other alternative being to swap the pistons to get around a 8.5:1 up to 9.5:1 ratio and then add boost.
as far ar the heads go; the stock parts in the heads were designed solely for gas mileage (meaning weak and light) and with more power and higher revs you will experience an overwhelming case of valve float.
good luck with your project!!
http://www.matrixengineering.cc
