Backstory: my buddy picked up a 98 RS ej25d with a blown motor. i disassembled it and find out the shortblock is toast and one head is toast. We sourced an EJ251 from an 01 RS and another ej25d head.
I got new ej25D headgaskets and tensioner as well.
We get the heads on and the timing belt all lined correct and this is where the trouble starts.
We cannot turn the motor over by hand past about one full rotation of the crank pulley in either direction. it definitely feels like something is hitting inside the motor. could it be the pistons hitting the valves?
What would cause this? A relatively simple shortblock swap has turned into a nightmare. We just want this car to run.
Side note: with the timing belt off, we can turn everything over perfectly. all 4 cam gears and the crank gear turn just fine, its just with the timing belt on that something locks it up and it wont turn past a certain degree in either direction.
RS25 please help. Tell me what i did wrong here/what am i missing?
thanks,
Curtis
thanks,
Curtis
