1 - 3 of 3 Posts
Black GC8
I need help to see what needs to be done to swap a ej253 non avls to replace my ej251. Leaking head gasket and 223,000 on it. Most likely a jdm non avls motor.
Super Moderator
2000 RSTi
Reuse your intake manifold, all electronics & sensors, and the crank sprocket and the one cam gear that has the timing pips on it.
You may find some or most of that stuff is the same as yours, but if you swap your existing stuff, you'll know for sure it'll work.
1 - 3 of 3 Posts
