2001 GME
Hey was wondering what you all think might be the cause of this new sound my engine is making. It's as if a new tapping sound is occurring, not at idle but at lower to mid rpms.
The car is stopped, clutch pedal depressed and transmission in neutral in the video, after a cold start. No check engine light. Started hearing it after a 900 km road trip. Engine oil level is full, oil changed recently 5W30.
Car has a seperate transmission noise which has been getting worse lately and original clutch.
Thanks for your help.
EJ251 Engine Noise
1995 EZ30 Coupe
Sorry dude, I think you'll need to try to get a higher quality video somehow, either borrow someone else's phone/go pro, etc. And take a vid from inside the car and under the hood, may help diagnosis.
Is it only when the engine is cold? Is it heavy/solid sounding or light and rattle-y?
1996 Green Impreza OBS
Hey 2000WRC, could you film a video in the engine bay? Sounds can be distorted in the cabin.
First things first, are you sure the sound is from the engine and not an accessory? Have you looked around the engine bay for anything else leaking or broken. For example, I have a loud rattle on deceleration in my '96 OBS with an EJ22 from a loose exhaust shield. I don't think this is your problem but it's worth checking throughout the engine bay to make sure you don't have another problem pretending to be an engine problem.
Second, does the noise change (get louder, go away, or occur higher in the rev range) once your car warms up?
Third, I see you checked the oil level. Is other engine preventative maintenance up to date (i.e. timing belt)?
2001 GME
Discussion Starter #4
Thanks for the help guys really appreciate it.
I think you'll need to try to get a higher quality video [...] from inside the car and under the hood, may help diagnosis
Could you film a video in the engine bay? Sounds can be distorted in the cabin.
Ok, I'll get another video.
Not sure yet if its only on cold starts. It may occur after a warm start too. I'll keep an ear on this.
On the lighter rattly side I would say.
I'm actually not sure it's from the engine. Good point. It isn't really audible at idle.
Looked a few times, couldn't see anything jumping out at me but I'm no expert. Screwdriver to ear method seemed loudest around the passenger side area. Removed the timing belt inspection cover thinking it might be the tensioner and it didn't increase noticeably.
If anything the noise seems to dissipate as the car warms up, and also, I can't hear the noise as it gets higher in the rpm range, say at around 4000 rpm it seems to disappear, but maybe the engine just drowns it out. It's not that loud.
No, the timing belt and all related components are overdue for service on time, but not mileage. Still about 14000 miles left for the mileage interval, but there's at least 5 years on the belt, if not more. The belt did look glossy when I removed the inspection cover. Oil changes have been regular. I replaced the spark plugs and fuel filter last week, rotated tires. The head gaskets were replaced professionally 40 000 miles ago. The car just came out of winter storage. I wonder if it's related to having the battery out, disconnecting the ECU and running a tank of high octane fuel after storage to help with old gas?
1995 EZ30 Coupe
$20 says it's the timing belt tensioner. Mine showed the exact same symptoms when it started to fail. With the cover off, I was able to VERY carefully and gently pry against it with a screwdriver and get the noise to stop.
