1993 Subaru Legacy SS
Picked this up from a local forum member to do a transmission swap on my tleg. Was going to put this off to the side and build it but I might be going a different route for my engine build.
According to po, was pulled from a tleg that ran and drove with 160k. The leakdown test was perfect I haven't done a compression test on it. Po did a comp test with a harbor freight tester, cranking by hand with cold oil and had 70s across all the cylinders iirc. I'm guessing the numbers are much better than that with an accurate tester and more cranking power :) if you don't know anything about these engines than you might wanna do a little research, all closed deck, oil squirters, and badass all around! I have one with 225k in my car now and its still running amazing. All non inference!!
Has no intake mani or exhaust. Comes with a vf11 turbo with 190k, no shaft play, but burnt a lil oil before I did a td04 swap. I cleaned it up and I'm located in the springs. It's currently located at Slodrive in Longmont but ill be picking it up along with my car this friday evening.
Looking for 800$. Here's a couple pics I have for now. Not looking for trades, cash talks. I'm in no rush to sell this, so don't care to lowball. Pm or post here to get ahold of me for questions/inquiries.
Also.... If you plan on picking it up, it should fit in your sedan/hatch/wagon trunk easily :)
2 broken subarus...
'00 Subaru Impreza OBS
Get wrx heads and intake manifold, and wrx ecu. Tunable dohc setup with a badass shortblock.
If I had enough money for this, I would've bought it already. GLWS
1992 Subaru Legacy Sport
price shipped to Lakewood, Wa 98439?
