1 - 7 of 7 Posts
2002 Impreza 2.5RS
I just bought an auto 1999 Impreza 2.2L with the plans to swap an EJ205 into with with the 5MT & diff.
I'm having a hard time finding a source to do the wire merge. As I know there are some differences between the 2.2L and the 2.5RS.
I'm hoping to start this swap this weekend, so any help will be greatly appreciated.
Thanks
Jake
2002 Impreza 2.5RS
An ECU only swap probably isn't the right way to go for a swap, but it is a possibility. I'm running a wrx ecu and intake manifold with all n/a wiring for instance. A harness merge should be a lot better with an actual wrx swap.
As far as your question, 1999 2.2 is the same as 2.5, only 00-01 are different (slightly).
99RS 207 V9 AW
With 99 ECU/IM/heads, you could swap EJ251 short block directly much simpler than EJ205 which requires harness merged. My nephew has Legacy 99 EJ222 phase 2/single port exhaust, he's swapping in EJ251 long block directly but have to get dual exhaust from RS.
2002 Impreza 2.5RS
Discussion Starter #6
I thought that the 2.2L were MAF while the 2.5RS weren't? I could be wrong with that.
Thanks for the help though
I already have everything for the EJ205 swap. Just need to install and merge.
I just can't find any solid sources/how to's for the 2.2L to WRX. I know there are tons of 2.5rs merge how to's.
1 - 7 of 7 Posts
