how would early ej22 heads work with a 205? would i still use the 205's harness?
Jake · Registered Joined Nov 17, 2007 · 9,301 Posts Discussion Starter · #1 · Aug 8, 2008 Only show this user how would early ej22 heads work with a 205? would i still use the 205's harness?
M mxpunk · Registered 02 F-150 Extended Cab Joined Dec 18, 2006 · 3,127 Posts #2 · Aug 8, 2008 Only show this user they wont..totalyl differnt..ej22 is phase 1 ej205 is phase II
Jake · Registered Joined Nov 17, 2007 · 9,301 Posts Discussion Starter · #3 · Aug 8, 2008 Only show this user thanks man
2slo4u · needs more cowbell 95L, 07 2.5i, R6 Joined Apr 18, 2006 · 12,639 Posts #4 · Aug 8, 2008 Only show this user Pretty sure you could bolt the heads on, but you'd need to use the ej22 harness. Don't know what compression would be, that would depend on pistons.
