Here it goes
I bought an EDM 97 wrx cluster that is LHD. Apparently a 97 wrx has VSS (not cable). My 96 L is cable so I swapped everything over to my stock cluster while utilizing the cable sensor (needle and gauge face swapped in).
Here's my problem... the temp gauge does not move (needle sits at the bottom and my gas gauge is sitting at half when I had a 1/4 tank when the stock cluster was removed. Reset the ECU and nothing changes. Any thoughts on this? I may just take it back apart but I thought I'd post first
Also on a side note my stock cluster tops at 140mph while the EDM one tops at 160mph so my actual speed is slower than what the speedo reads. Easy fix is to just swap the stock one in using the EDM needle but I figure I'd check to see if there is a way to keep the EDM one and read correctly
Thanks
Alex
Video
P.S. If anyone knows how to embed a photobucket video lmk
Thanks
Alex
Video
