when you swap a motor like say a 05 sti motor into your rs, instead of rewiring the harness, why don't people just buy a 05 sti ecu? is that possible?
N00bwhen you swap a motor like say a 05 sti motor into your rs, instead of rewiring the harness, why don't people just buy a 05 sti ecu? is that possible?
Thanks for that helpful comment..N00b
with any turbo engine you're going to need the ecu for that engine.....when swapping there really is no way around ecu swap and harness mergingyes thank you for the helpfull and not so helpfull comment. But anyways, what would be an easier swap than a 05 sti motor? would the 05 wrx motor or is it still ran by computers?
I dont know of any EJ series motors NOT run by computers.yes thank you for the helpfull and not so helpfull comment. But anyways, what would be an easier swap than a 05 sti motor? would the 05 wrx motor or is it still ran by computers?
oh and would the install be easier for me because if i'm not hooking up power windows, power mirrors, dome light,a/c,and air bags. are those the things you meant?The re-wiring part comes in making it work with all the other crap on your car that you can't convert.
Its actually the other way around. Most of the engine bay stuff remains intact since you would be using the 05 ECU, you splice in the necessary dash components, etc.Actually, I think that people who merge (say for an example) an 05 wrx engine harness with a 99 rs harness merge only the wires that matter for the engine and supporting accessories contained in the engine bay. If it is done right, things like doors and windows that stuff should be untouched.
As a tool , I cannot speakno hahahah sorry, let me clarify, i meant if the 05 wrx still ran by electric or is it throttle cable?
