1 - 9 of 9 Posts
99RS 207 V9 AW
I have both f/r Cusco strut bars and they handle very fluid in corners, less roll. Adding sway bar and KB/WL end links tie everything together, handling is more fabulous. I never care about looks but I know Cusco is best at suspension components besides Whiteline.
2002, 2.5rs, black
Discussion Starter #5
awesome. thanks. I have an old factory sway bar from my wrx and that even made a difference. I'm sure your cusco strut bar works great, I just wasn't sure if these cheapies would be more prone to flex or something.
99RS 207 V9 AW
Rear WRX sway bar is 20mm replaces 13mm RS stock will make big difference. For rear strut bar, save $$$ better use eBay. For front, Cusco bar has slight preload make it better than FHI CF strut bar IMO, don't go cheap in the front.
2002, 2.5rs, black
Discussion Starter #8
thanks for the help. I'm going to give it a go and save up for a front bar and a set of AGX's
2000 Impreza OBS
I just bought a set for front and rear for 50 from eBay, my rear look identical except for coloring. I noticed a huge difference. Waaaaay worth it for the money.
Sent from my SCH-I535 using Tapatalk
1 - 9 of 9 Posts
