1 - 9 of 9 Posts
1991 Nissan 240SX turbo slider
I have a 99 Forester L with rear drum brakes and ABS.
Will a 95 Legacy Sedan rear drum brake assembly bolt on no problems? Will the control arm be the same as well?
Back story:
Last night I hit a curb and the wheel came off(due to not long enough studs for the rims I had). Had to limp the car along for 100ft on the rear hub. When the wheel came off it stripped the hub studs so that's why i need a new hub on there.
Yes i searched the Web for an answer but couldn't find a clear one. Thanks guys
the hard way
1972 240Z
i really dont know, but to try to be helpful, i think it would come down the the ring that bolts on to the hub surface. if those are interchangeable (as well as the cable that plugs into the hub) i think youd be ok - at least id be confident enough to buy and try it. part numbers may likely come out to be different even if they are the same dimensions though so.... i dunno. good luck.
Wannabe JDM GF4
Another thing to think about is spline count on the axles. Whether or not the forester Axle will have the same amount of splines as the leggy hub.
Wannabe JDM GF4
Damn man, Insane.
Wait so you had to drive only on the drum? Did you hurt your center diff?
MY98 2.2 Swapped Foz L
Check your lateral links, you probably royally fudge'd them on the curb. Stock ones bend really easy.
1 - 9 of 9 Posts
