I have done some searching, but I can't seem to find an issue like mine. I know a bad throwout bearing will make noise with clutch pedal pressed, and input shaft bearing with clutch engaged, however my case is a bit different. Car is a 2000rs sedan mt with 110000k. When in idle no noise, clutch pedal pressed no noise, when in gear (any gear) I have a whine, bud only when on the throttle and the clutch engaged, if while moving I press the clutch whine stops, if while letting off throttle in gear noise stops. In neutral and revving no noise. WTF! Is this it's driving me crazy. If you have ever seen a video of the Subaru wrc car from the cabin you can hear a whine noise from those cars, that's exactly how mine sounds. Also the sound is cimming from mid to front of car, not rear.
