1 - 2 of 2 Posts
1999 OBS black pearl (suki)
Occasionally when it's warm enough for slush to form
On the ground, my door locks randomly lock, and when I try to unlock them with the button, they re lock.. I can operate them manually just fine. I don't have a fender liner on my drivers side & there is some wiring tucked under the fender. Do you guys think that may be part of my problem? My other thought
Wound be a pinched wire somewhere.
00'RS/02' WRX stgEleventy
If there's a problem beyond a wonky switch maybe its more likely in the kick panels..
The door harness has a connection there.. I had to bypass the connection in 2 different places because the pins where burn/corroded..
1 - 2 of 2 Posts
