1 - 18 of 18 Posts
95 GC 371hp/355tq ej25 1.5xtr
Tools required
10,12mm socket/wrench
1/4 drive
Flathead screw driver
Common sense
Also refer to here... http://www.rs25.com/forums/showthread.php?t=83925
Slava also helped me and has the tank mounted. so additional info is also found there.
Thanks Slava!
Here are the materials i used... i am so pissed at my camera(sorry about the pics):mad::mad::mad::mad:
i got 20ft of wire but i came up short. so get 30ft
12ft of 1/4 tube
zipties
here is what we will be working with today
take off the two 10mm bolts, wire clip, and tube
once its all out it should look like this....
i cleaned everything up....
the motor just pulls out
i also removed the fuses to clean better
all cleaned up
Next take off the tube on the BOTTOM and put the new 12ft tube on...
i found a grommet under the brake booster to run the tube through the cabin, you will also use this same one for the wires.
Now take off these things with the flat head screw driver, and run the tube under it
Next i started to remove the back seats to continue to run the tube. just tuck it to the side and out into the trunk
Next i ran the wires from the engine bay. i used some vampire clips, do this for both wires and make them follow the tube you already ran to the trunk
now it should look like this in your trunk ( the tube, and the 2 wires)
assemble everything together, like the back seats/door still things
make sure you get the right wires on the pump. plug them in using some wire things that fit on...(lol i dont know the name) plug in the tube and fill with some water and test it out!!!
hold it down for a few secs...
IT WORKS!!!
i didnt have time to mount it anywhere to the trunk so i will update this another time. but i am sure you can figure something out as well, but enjoy your open/clean engine bay and but the tank on the passenger side if your anal about corner weight but good luck
DISCLAIMER: i am not held responsible if you fuck up your car or make a mistake. please ask me before you do something you are not sure about.
remember USE COMMON SENSE
Discussion Starter · #4 ·
now make the bottle smaller. i used a water bottle at first. lol
i was thinking about fabing one up that would sit behind the strut tower. i would get one from a junk yard and cut/melt it
needs more cowbell
95L, 07 2.5i, R6
Are you doing this for weight distribution?
99 WRB GC V9 Spec C RA recce
and the spray pattern is strong with enough pressure?
I wonder if I can use my spec c 12l tank for IC spray and windshield washers, and keep the OEM windshield washer tank for water injection...
Discussion Starter · #9 ·
yea i was surprised my self. it does have enough pressure.
Red/gray 1995 Impreza LX Wagon
takes a little bit to kick in but works fine. just little lag. that all
E30
the washer pumps from the I/C sprayer reservoirs work with out a hitch. if the pump became an issue, you could always just use one of them.
Discussion Starter · #14 ·
i mounted mine on the passenger side. i made a bracket that attactes to the 2 small bolts of the tail light. my next problem is that when i go down hill or hit the brakes hard the drivers side nozzel squirts out fluid. idk why, anyone else with this problem. my first guess is that since its a long tube all the fluid in it rushes toward the front of the car when i go down hill or hit the brakes.
'MURRICA!
Hybrid Camry
Guys, get a rear washer tank from a '93-'95 wagon. Those years have 2 tanks, one in the front for the windshield, one in teh back for the rear window. The '97+ have a tank with 2 pumps on it (good for I/C spray I guess) and run a seprate line to the back of the car.
Anyway, should be easier to mount the flat tank on the side somewhere, and it's got a long filler hole thing to plumb it somewhere easy to fill.
im using a 93 wagon rear tank to relocate my washer tank to the trunk...i just havent gotten around to getting hose, or anything else...all i have is the tank so far.
1 - 18 of 18 Posts
