1 - 15 of 15 Posts
98 2.5rs
Hello Everyone
I will be leaving the country for 6 months to pursue an internship abroad. During that time my car will not be used so i would like to store it in the family garage.
There are quite a few guides on the net but many have different and sometime contradictory information. I though i would also check in with the many knowledgeable people here.
How do you recommend i prep the car for home storage?
thanks
07 subaru outback LLbean H6
Jack stands take tires off. Full tant of gas so it could be started from time to time. disconnect the battery. I would set some mice traps becasue with the colder weather coming they are going to be looking for a home as well.
2000 Impreza Sedan
+1, but if it can't be started i'd drain the tank
Rafal
2006 Impreza WRX Limited
fuel stabilizer, jack stands... block your intake piping and exhaust piping so nothing can go in. Hopefully mice dont chew threw your wiring harness...
2003 Outback Sedan H6
^ All this happened to me. Don't leave the car outside. Close your windows, put cling free sheets in your interior (gets mice out of there), put the car on jackstands, disconnect the battery.
Close your heater vent so its only recirculating inside air.
Low&Slow
1965 VW Bug,2001 drz400 sumo
fuel stabilizer, jack stands, full tank of gas so you dont get condensation in there, cover intake and exhaust, disconnect battery, and dryer sheets in the interior.
Low&Slow
Drain your oil, tranny fluid and coolant? Dunno, just intuition...
no bad... it allows moisture to rot everything. bearings will be toast, and alot of corrosion in the complete systems because of the aluminum, major rust on steel/cast iron.
ask me how i know. had to build a completely new engine for my 78 chevy truck after storing it for 14month while i was out of state at college. oh well it now has 510WHP and 596WTQ.
'99 Hybrid RS Coupe
I've let my RS sit for 2 6-month periods. One time it was left in the driveway and the other time it was left in the garage. I left the worst wheels/tires I had so I wouldn't care about flat spots (didn't get any either). Car was started every 2 or so weeks and driven around the block (no plates or insurance). No fuel stabilizer was added.
6 months isn't a terribly long time unless you never start or drive the car. I'm gearing up for another 6-month time period with the RS off the road and am contemplating more preperation because I won't be around as much to start the car.
\m/(-_-)\m/
03 350z for now
If the car has valvecover gasket /oil pan gasket leaks, I'd make sure to make sure there's some oil before starting when returning from your trip.
2005,Impreza RS Black Pearl
I've stored cars in my shop for longer than 6 months with great results.. Drain fuel or add Stabilizer, Fresh oil change, Pull plugs and shoot oil down the cylinder to eliminate rings from freezing up 1 Tbs, Cover exhaust and intake with a rag and then plastic, Jack Stand the vehicle, and finally put a paper plate on the floor of the car the with a 1/2 cup of baking soda. the paper plate and soda will draw any moisture out of the air. if possible always put a cover over the vehicle or sheets..
Best of luck.
I Miss My OBS..
07 Legacy Spec.b
I'm having to park mine for about 4 months. Unfortunately, I'll have to leave it outside, and my driveway is slightly uphill. So, no jacks. How probable are flat spots and suspension sag?
EDIT:
Also, thinking of chocking it instead of putting on the brake. I've had too many nightmares with rust frozen brakes!
05' Silver RS
I have a pathfinder that sits for periods I try to drive it every other month or so.
For 6 months the only thing I'd worry about is the battery. If it could be started every once in awhile to charge it then it's all good. If it can't be started then just disconnect it and make sure you have a charger for when you need to start it.
Also if you use mineral based motor oil you'll want to change it when you get home.
Flat spots are unlikely after only 6 months, modern tires aren't nearly as bad as the old bias ply ones, but some stories persist.
As far as the rodent problem..... depends on where you live I guess.
sold it to Susie the Subie
car cover for sure to protect paint from dust and dirt. Or the sun if you're leaving it outside (not all of us are lucky enough to have a garage)
1 - 15 of 15 Posts
