Is heater hose ok for use on the pressurized side of a fuel injection systems?Graham said:My lines are just simple heater hose lines, nothing special.
Graham: what kind of T connector did you use to tap on to the passenger side rail and the in line?
Yes, his way should work just fine with the stock FPR. Zaidoun's version, however, would not work since the FPR requires TWO inlets on the FPR, not one like the stock unit. I would brass T's are fine, if you can find them in a Y configuration.would boy's way work also using, say just brass T's and fuel injector hoses, while using the stock FPR
the stocker will be removed completely.
Thanks for the heads up, good thing I haven't done my // rails yetGraham said:Bill, many people have tried to run the 2 in 1 FPR and RRFPR units with the RS, without any luck. It would be in your best interest to run a seperate FPR unit from your RRFPR.
Graham
I don't get it. Isn't a RRFPR just a FPR with the ability to increase the amount of fuel pressure based on a vacuum/pressure signal? I don't understand why you can't just run the RRFPR by itself.Graham said:Bill, many people have tried to run the 2 in 1 FPR and RRFPR units with the RS, without any luck. It would be in your best interest to run a seperate FPR unit from your RRFPR.
Graham
Well, are you familiat with the Vortech S-RRFPR? It is a unit with a baseline FPR function, as well as a RRFPR capability. Imprezinator attempted to put one on his RS-T, and had NO luck getting a solid 35 or so baseline fuel pressure, while still raising pressure while on boost.I don't get it. Isn't a RRFPR just a FPR with the ability to increase the amount of fuel pressure based on a vacuum/pressure signal? I don't understand why you can't just run the RRFPR by itself.
Thanks for the heads up, good thing I haven't done my // rails yet . Hmmmm, looks like a bit more engineering for me before I start cutting anything.
Ah, that clears it up. So I guess I'd need to go with something like what Boy is doing, with the 2 Y-blocks, or maybe a regular 1:1 FPR with 2 inlets?Graham said:Well, are you familiat with the Vortech S-RRFPR? It is a unit with a baseline FPR function, as well as a RRFPR capability. Imprezinator attempted to put one on his RS-T, and had NO luck getting a solid 35 or so baseline fuel pressure, while still raising pressure while on boost.
RRFPR have plates that act when pressure goes over vaccum, such as 2 psi, not just 1:1 like a normally aspirated car would see. FPR's only have one to one plates, so your not getting rise in pressure. The RRFPR give you on boost response, but it has nothing to act off of for baseline pressure.
Graham
