1 - 4 of 4 Posts
01 coupe
01 coupe, Im having a problem with left head lamp being dim, Changed old beat up plug that powers bulb. Bulb is good, Cleaned ground where wires come up from fender well. Dash high beam indicator seem dimmly lit when high beams are not switched on. Can anyone help me out, Thanks
2000, RS Coupe, BRP
Look for a blown head lamp fuse. They are powered individually. When a fuse is bad the high beam element of the bright headlight powers the high beam to the low beam then to ground of the dull head lamp.
[email protected]
1 - 4 of 4 Posts
