1 - 18 of 18 Posts
Banned
We are Open Late7 Days a week!
RallySportDirect.com are happy to announce the release of 2 highly anticipated products!
At the 2011 SEMA show, DeatschWerks has debut 2 brand new fuel pumps. The DW65C and the DW200.
DW65C LINK!
DW200 LINK!
The DW 65C is a industry first direct factory replacement fuel pump for the 2008 WRX and STi, along with EVO X. No more grinding, retro fitting, or modifying your stock fuel pump housing to fit a fuel pump. This great new design is a simple OEM direct replacement that is a Remove and Replace procedure. The great compact design, high fuel flow, and ease of install make this the ultimate option for any 2008+ Impreza owner! And with E85, Race Fuel, and conventional fuel compatibility matched up with the 265lph at 40PSI pressure flow this is a No brainer solution for any GH and GR owner!
The DW 200 is a brand new pump released as a alternative cost effective option for the DW300 where as high of fuel flow is not needed. Featuring the same dimensions and installation, this is a great pump for someone doing a build medium size build or needing a OEM replacement pump. With a flow of 255lph at 40PSI, this pump is able to supply fuel you need in a cost effective package!
Also dont forget that all DeatschWerks pumps feature a 3 year No Fault warranty. A industry first series of fuel pumps to offer that!
The Brand new DW 65C and DW200 Whats in the box Videos!
Check these out for a great detailed overview of the all new units, going over the great design and to help you better select the proper fuel pump for your application!
DeatschWerks Fuel Pumps - What's in the Box? - YouTube
Also the in depth view of the all NEW DW 65C pump for the 2008+ WRX and the 2008+ STi! Industry First true drop in fuel pump!
DeatschWerks DW65C Fuel Pump (08+ WRX/STI Fitment) - What's in the Box? - YouTube
Impreza GT (RS) '98 260HP
Just bought original DW200 (9-201) with DW301 fitment kit (9-0791) and have a question about included filter.
In Walbro pumps you need to install oem subaru filter on pump to prevent gap in fuel supply. This is cause Walbro making too short filter.
Should I do the same with DW200 like installing pump on oem subaru filter OR I can with no problem install DW200 filter which is included to fitment kit ?
MY05 Impreza 2.5RS Aqua blue M
I can confirm - Have customers with the DW300 pump, all very happy with the product. One of the few very high performance pumps that are SILENT
'01 Honda S2k & 2.5rs Coupe
My stock fuel pump has started going bad on my 01 RS coupe :(
Would the DW200 be a suitable replacement for a stock car? What all do I need to install this? Is there anything I should know before making this purchase?
Thankyou!
1 - 18 of 18 Posts
