1 - 3 of 3 Posts
Cant find any info on this, Does anyone know if you can swap EJ25 DOHC heads for the EJ20 DOHC heads?
Also if you could put the EJ20 cams in the EJ25?
thanks justin
2001 Silverthorn Coupe
Cobb puts a 2.5 block under 2.0 heads in WRXes, so you can put the 2.0 head on your engine, but it might require a few little things to do it correctly.
THe cams are not interchangable.
cheeRS,
Greg
1 - 3 of 3 Posts
