ok so i am pondering going turbo again (it is seriously an endless battle in my brain) but this time i think i might have come up with a solution for money and power. i dont want to make a crazy load of power, so i was thinkin of maybe building a avo style kit. and since i didnt want to throw down 3g's, it seemed like a better option...
this is what it would entail:
-TD04 turbo with wastegate welded shut
-TiAL 38mm EWG with 5.8psi spring
-WRX downpipe (i have wrx exhaust so this would match perfectly to catback)
-Walbro fuel pump
-PP6 for engine management
-uppipe with EWG flange
-LGT/WRX/STI stock manifold-my only concern with this is the crossmember, if i notch it will the up pipe and manifold still fit ok? i know the cruise control will need to be moved or eliminated but is there anything else in the way if the turbo sits in stock wrx location?
-AFR gauge/sensor
-Vishnu TMIC
-Boost gauge
-TiAL 55mm BOV-btw i have a 2000 rs, so i have a map sensor, so the atmospheric BOV shouldnt be a problem
i figured it would work like the AVO kit, but just a homemade version. not pushing crazy boost so the tranny will be ok and so will the stock block
what does everyone think? yay? nay? comments? suggestions?
anything and everything will help guys!
thanks!
-Walbro fuel pump
-AFR gauge/sensor
-Vishnu TMIC
-Boost gauge
thanks!
