picked up a car that had been sitting nearby for a long time. will crank fine, old fuel is pushed, sounds normal just not catching. appears no spark until i let go of key. obd2 codes for cam and crank position sensors p0336 p0341. begin measuring voltage and resistance all over.. i see continuity from the ecu connector to the sensors and both sensors test at about 2000ohms which is within subaru spec.. 1-4Kohm?..
has anyone seen these test good and then replaced it and had it work?? i know their not too expensive but some of the point of fixing this is troubleshooting practice. i dont have a backup ecu to verify the one in the car. should probably just replace these parts anyways as part of upkeep/restoration. not expecting too much from writing my diary.. i mean this forum
