1 - 7 of 7 Posts
i recently bought a gc8, and it has kyb agx struts, and h&r springs. i also have the stock springs, which i want to put back in, my driveway sucks and i need more ground clearance. is changing the springs a relatively easy job? and if it is how is it done. thanks
Scoobymods Guy
2010 Legacy 3.6R Limited
Do yourself a favor and soak the bolts at the bottom of the struts overnight with liquid wrench or something. You'll be glad you did :)
Discussion Starter #7
doht! that would be why my car sits low in the rear, and high in the front. my stock springs were labeled wrong in the box, and i put the fronts in the rear, and so forth. i just about have the driver side swapped, but had to make sure. all the help is much appreciated!:)
1 - 7 of 7 Posts
