I've got a 1998 LGT with the 2.5 DOHC motor.
My primary cat has failed. Or the second O2 sensor, either way, both are getting replaced.
So, should I replace the secondary cat as well?
Pros: Using high flow cats, I'll get better performance
Going to put both cats before the O2 sensor so I have less chances of getting a P0420
Not risking the possibility that the second cat is plugged
Cons: More expensive
Opinions? Remember, I gotta make sure this car passes emissions, so no going catless.
Plus, no local shops are willing to do that anyway.
