Hi I have a 1995 impreza L with the 2.2 motor and previously an auto tranny. I swapped in a 5spd from a 1997 legacy. I did the wiring myself wich include soldering the 11 and 12 pins together in the auto harness as well as remove the tcu and ignition interlock box. the motor will crank but wont fire, I have spark at all four plugs, as well as fuel as the plugs are wet and I can smell raw gas. Every once in a while it will catch fire at the throttle body as well as sputter and belch a white smoke from the exhaust, when I turn on the key i hear the pump cycle on and then off and then on then off then on,
does anyone have a jumping off point here
thanks
thanks
