1 - 4 of 4 Posts
1995 Impreza 2.2L FWD
well my car has been having some problems
about two months ago my car started cutting out and bogging down while driving so i just let it sit a couple of weeks till i could do my swap
did the swap about 3 weeks ago and ran fine but it started bogging down while driving and will die sometimes when i come to a stop
im using the intake manifold from my old engine so i believe i have a bad sensor or something could it be the idle air control valve, throttle position sensor
Rally Hopeful
1997 L White - 2004 STi WRB
Check your MAF. I had a maf go bad, caused the engine to run very very rich, bog down, stutter, cut out compltely. All of this was a bit random, but if you can data log your fuel trims, they will be all over the place if your maf is bad. Try a junkyard 2.2 maf, they are found !$15 or so. Thats what I did, my car runs like a champ!
1 - 4 of 4 Posts
