1 - 8 of 8 Posts
2005 2.5rs wagon
Hi! i’m new here and i’m new to subies. I baught a 2005 2.5rs about 2 weeks ago. everything was fine with it until the other day. everything was fine with the car, nothing was running wrong or giving any indications of a problem but when i tried to fire it up after a quick drive, the car wouldn’t start. i tried a couple of times and sometimes it would start but idled extremely rough for 10-15 seconds and die. it felt like the car misfired at low rpms or it would go up to 2000 rpm and drop/die. the car is bone stock and has 155k kms on it. The car does not give any CEL for the brief moments it idles.
2005 2.5rs wagon
Discussion Starter · #2 ·
If it can help, the car does not respond if i give it gas, it just wants to die even more.
'96 OBS
Do you have a way to pull the OBDII codes? You said it shows no CEL, but It kinda sounds to me like a sensor failure of some kind, maybe MAF or MAP. Even if you were completely down a cylinder (due to a spark plug or spark plug wire) it should still run and smooth out a little with a bit of gas. You probably checked, but just to make sure: does it have fuel? If you've been cranking it and having it die, it should probably smell at least a little bit like gasoline around the engine bay, especially if you disconnect the intake duct from the manifold and have a sniff.
2005 2.5rs wagon
Discussion Starter · #4 ·
I scanned it yesterday and nothing came up on the scanner :// its still has a 1/4 tank left of gas in it so it should be good and i’ll disconnect the intake and sniff around it! i’ll let you know if i can maybe find some more clues on this!! saturday i’m not working so i will try and find whats wrong with it all day.
Thanks alot!!
02 RSX type S dd, 96 Brighton
Have you checked the intake tubing for cracks or breaks? Had this issue on my '86 pickup recently.
2005 2.5rs wagon
Discussion Starter · #6 ·
I checked mostly around the airbox but other than that i didn’t. i’ll check tonight when i get home from work and i’ll let you know!
2005 2.5rs wagon
Discussion Starter · #7 ·
FIXED!! I can’t trust the gas gauge on it!! it was just empty on gas. Thanks a lot for your help guys!!!
1 - 8 of 8 Posts
