My car is a 98 impreza with an 06 wrx swap. everything mechanical in the car is from the wrx as is the wiring harness. I had to pull the engine to do some head work on the car, but now the engine is back in and bolted up. However, right now, for some reason, i cant get the car to start.
The car would crank and start before i pulled the engine, so i can't seem to figure out what the problem might be.
Here is what i have found
- started clicks once and all the lights and stuff go off inside the car as long as the key is held to the starting position
- the battery cables get hot for some reason, no smoke, but they get pretty hot
- the little black clip that goes on the starter along with the main battery cables is properly plugged in
- my battery is good and was fully charged before i tried starting again
- I am 98% sure i hooked up the battery cables to the starter properly, i can't see another way they would go
- all the wires in the car are properly grounded and connected, as are the battery cables themselves
- i had the starter tested once and it passed but the guy said it sounded weak, not sure if that mattered or not
I am going to get the starter tested again today just in case, but otherwise, i dont know what to do or whats wrong, and i'd love to hear my car start again
thanks in advance
thanks in advance
