Found a coolant leak from a hose passage, but I can't find the P/N to it. Also when removing my TB to make space, the top vacuum hose broke (was quite brittle). Checked OpposedForce and couldn't find them. Not sure if the TB vacuum hose could be used with any generic silicone vacuum line?
Sink Black Motor vehicle Hood Automotive lighting
The coolant passage hose is passenger side underneath the TB
Automotive tire Rim Natural material Tints and shades Automotive wheel system
Automotive tire Tire Motor vehicle Automotive lighting Wheel
The skinny one you don't need a part number for, just take your hose and go to any parts store. They have a whole spool of them, if I remember correctly it's 3/8 or 5/16 (likely the latter)
I'll give that a shot, thanks for the advice! Now to find the coolant passage hose. Debating on getting a coolant hose similar mold
You can use this site to find OEM part numbers. You can get a similar mold and cut to shape what you need if it is longer. Just make sure it is the same diameter and similar mold since you don't want the hose to have a kink in it restricting coolant flow.
