61 - 80 of 521 Posts
#32
95 Coupe, 95 Sedan & 95 Wagon
Discussion Starter #66
I just used Gunk engine grease cleaner, brake cleaner, regular, warm water, a brush, and a rag or two.
I spray the gunk, let it sit for 5 minutes. Use the brush to agitate the dirt. It's all about patience. Let it sit, maybe spray a little more, agitate again. rinse with water, start over. Each time you clean a layer off, you can get to more staring over. I spray a little brake cleaner too to rinse it off at the end and wipe!
Y2K GM6 & 65 'Stang Fastback
Well if I can get a 6 speed from a friend of mine I will have a full Ver.5/6 JDM WRX 5 speed setup available! lol. Just a thought...
96 L Turbo Wagon
I was tired of not being able to see the radio when the drink holder was out. So I moved it down, and took out the din pocket. I put some Lamco gauges I had lying around.
Oil temp and vacuum line
Open port on the IM
Took about 15 minutes
I will connect the oil temp next oil change.
Awesome setup. Almost exactly like mine. I converted my lamco gauges to red led but i really like the white.
Sent from my DROID RAZR using Tapatalk 2
