1 - 3 of 3 Posts
Thinking about purchasing Brembo Brakes (from JDM 2003 STi) for my 2000 2.5 RS...
the front 4pots should install fine...just a couple of questions
running stock front brakes w/ Goodridge Stainless Steel Lines...
will these Brembo front brakes work with them ?
and how do i get the rear 2pot Brembo to work on my RS?
thanks
i don't know the answers to any of the questions, but i sure wanna see pics b4 and after the install.
FaLeX,
The 326mm dia Front rotors will bolt on after removing the backing plate. The Goodridge lines for the GC/GF bodies, I am checking on fitment. The 316mm dia. Rear rotors will only work with the R180 rear (your RS has an R160 rear) with the 190mm dia parking brake. It is possble to do the upgrade, although I would say go with a more economical upgrade like like the ver 5/6 or GD WRX 294mm dia Front rotors, 290mm dia H6 Outback Rear Rotors (for the 170mm dia parking brake) both from DBA, Subaru 4 pot calipers in front and 2 pot rears, with sport pads and Goodridge stainless steel lines. This is just my suggestion though.
Troy
1 - 3 of 3 Posts
