I have a brake line leak on my rear passanger brake line on my 95 impreza L with drums in the rear, non-abs. The rear brake lines go from the drums above the gas tank and into the chassis of the car and if you lift up the rear seat they are right there. Basically Im having a slight problem figuring out which brake line goes to which side of the car when you lift up that rear seat, because its hard to tell from looking under the car since the lines go over the gas tank. Ive looked and searched for diagrams or threads with similar issue but nothing comes up.
Here I have an image of the brake lines under the seat and from my guess the right one is the one that goes to the rear passanger side but I just need confirmation from someone on here
