G
Guest
·OK so tonight (on an undisclosed private (of course!) road) I was messing around and did a brake check from about 115. The results were pretty scary. The first 1/2-1 second the brakes grabbed hard and the tires squealed as I slowed down to about 80, but after that they felt way mushy and didn't seem to have the same grip, and I slowed down way slower (115-80 was fast, 80-50 was sloooow). Would this be fade caused by out-gassing? Stock rotors/pads, SS lines. Could it be cured by getting better pads and slotted/drilled rotors? I had the brake pedal mashed to the floor, and the ABS wasn't pumping, so I know that wasn't the problem.
