First off, the car is a MY00RS with and 07WRX motor swap. 18g, ebay tmic, 800cc injectors, gimmick inlet, gm bcs and all the basic supporting mods, tuned via Opensource.
The car has been a great car on this setup for 2 years now. I stopped modding because this was my DD. However the other day, my starter took a crap on me so I had to replace that. In the process, I had to take off my TMIC and that was about it. After installing everything, the car idles fine, and runs fine up until I try to get into boost. Everything is smooth until I hit about 10psi, the engine chokes, and bogs and I left off. However if I force it, it will still hit the target psi of 20psi. My AFRs all seem about right (11.2-11.8) under boost and are normal at cruise and idle. There are no CELs and my gas mileage is still the same. I am befuddled!
Any help or suggestions would be great!
Here are the things that I did so far:
Checked all vaccum lines/hoses but no leaks. Cant hear any either.
Thought it could be me wastegate but it isnt.
Thought it could be my GM BCS so I routed my wastegate straight to my turbo to run 10psi and still the engine acts the same way at max boost.
