1 - 10 of 10 Posts
So, I've been doing some research and I`m really stuck on which motor and other components are best for my 03 2.5 RS all tips and suggestions will be EXTREMELY helpful and looked into carefully!
Thanks!
Administrator
2000 RSTi
Can you describe what "best" means to you?
Administrator
2000 RSTi
Well, like the saying goes,
Fast
Reliable
Cheap
Pick 2
Administrator
2000 RSTi
Basically a full STI swap with a full forged rebuild of the engine is what you're after.
Honestly, it would be cheaper and more reliable to buy an STI and start from there.
Administrator
2000 RSTi
The Japanese version 8 STI, aka the version 8 ej207 would be my favorite all arounder.
It's durable and can handle 400hp without rebuilding the internals.
Administrator
2000 RSTi
For example:
And no Subaru 5 speed will hold the power when you're pushing it, so you need an STI 6 speed.
Example:
Clutch kit to hold big power: $750+++
Sti wiring harness $several hundred
Having Iwire or another company merge your wiring with the STI's: $1500+
You probably want to stop, so a set of brembos, quality pads and rotors: $1200+
Wheels and quality tires that clear your brakes $$$
Exhaust? $$$
Fluids, timing belt, gaskets, sensors, misc parts, etc. Easily $1000, could be significantly higher
Estimate your car will be down for a few months.
And so on. What I'm trying to illustrate is you can very quickly exceed the cost of an 04-07 STI, and still have a car that you can't sell for anywhere close to the money you put in.
Don't get discouraged, but just know that financially it may make more sense to start with a factory turbo charged car and build that up.
For example, in my area (Greater Seattle area) there are always WRX's needing an engine or trans or both, for $2k-$4k. Hell my friend just tried to offload his running and driving WRX 5-speed wagon (rough body) on me for $2500. I just don't need 3 turbocharged Subarus lol.
1995 EZ30 Coupe
My favorite engine is the ej22. You can take an old 2.2 block and put turbo heads on it for a super cheap, decently fast motor. I ran 18 psi on a 2.2 block with 2.5 heads that I modded for turbo oil return, it was all old 90's non turbo stuff. If I had put a new oil pickup in it I'd still be running it today.
That's probably about the limit for that setup, but cost/power ratio can't be beat. If you have loot get the aforementioned ej207.
Have you considered engine management?
1 - 10 of 10 Posts
