1481 - 1493 of 1493 Posts
IwannadrivelikeBunta
'98 RSTi, '10 LGT, '17 FXT
Discussion Starter #1,481
I'm also replacing all the coolant hoses.
Did the heater hoses:
The top and bottom radiator hoses:
Going to bypass the OEM Oil "cooler":
And replaced the water pump hoses:
Had to take the radiator out to get to the OEM oil cooler hoses:
Discussion Starter #1,482
Got the coilovers back, assembled and installed
And reinstalled the radiator and filled her up:
Discussion Starter #1,484
Got my fiance into a Subaru finally, a 2017 Forester XT Touring in Quartz Blue Pearl!
99'RS w/EJ205, 16'340i 13'Volt
nice updates here. I feel like I'm betraying the forum by being more active on FB and insta even though I was never a big social media guy.
Discussion Starter #1,487
No worries, I mainly post on Insta. I just followed you lol
Discussion Starter #1,489
Got the Getadomtune 4th cylinder cooling mod in, I should have done this before I filled up the coolant but I just drained and reused the new coolant. Install was pretty easy, but I removed the TMIC and did the work from both the top of the engine and the under the car:
Discussion Starter #1,490
The OEM rear endlink had its threads stripped on my daily so I ordered in some whiteline endlinks and installed them:
Discussion Starter #1,491
I replaced a lot of components on my rear suspension too. I got new rear trailing arms off a guy that builds them on ebay. He doesn't have a website but they look like quality pieces with huge bearings and they are about 1/4" shorter than stock for lowered vehicles. His shop was called Road Race Motorsport, he claimed these would be the last set he made because he wanted to get out of the gig to spend more time with family:
I also installed Whiteline rear adjustable lateral links with the tow lock kit. I used my OE links to get them to the right lengths before the install and I'm going in for an alignment this week:
And the tow lock kit sets it up so that the OEM tow adjustment is disabled since the link will be doing all the adjustment for camber and tow:
Discussion Starter #1,492
Got the car aligned at West End and took some photos last week:
Discussion Starter #1,493
I've been having a small oil leak for god knows how long:
I thought it was the turbo oil drain tube or gasket so I took the turbo out:
But it turns out the leak was from the oil feed tube from the head to the turbo and AVCS. I cut it apart and got it out, I'll be replacing it with a ss line one when that comes in:
The car has been having starting issues with the starter. In fact when I left West End it couldn't start and I had to push start the car. So I installed a rebuilt starter from Denso:
