1461 - 1480 of 1523 Posts
IwannadrivelikeBunta
'98 RSTi, '10 LGT, '17 FXT
Discussion Starter #1,462
Yeah, I'm not the original owner, I got them second hand, but never mounted.
Discussion Starter #1,464
Did an autox in mid September to shake down the brakes, they're not very good for autox because they need a lot of heat in them to work:
Discussion Starter #1,465
I added a water temp gauge because I don't really trust my OEM one. On cold days sometimes right when I turn on the car the OEM gauge would read operating temp right away:
Since I removed the key cylinder I had an ugly hole where it was so I 3d printed a plug to cover it up:
Discussion Starter #1,466
As always, an oil change before a track day at ButtonWillow:
And since Subiefest was the day after Buttonwillow I washed my Work Emotion CR Kais and added some more stickers before the track day:
Discussion Starter #1,467
The car survived another track day! The front splitter also survived an off with no problems. I had a slight improvement in times on these tires which were a best of a 2:09.49 from my last 2:10 but couldn't get past my PB of 2:07 on hankook RS3s.
My friend took some awesome pics:
And here are pics from Caliphotography:
Discussion Starter #1,468
I barely made it to Subiefest! After the track day we had dinner and I had a severe allergic reaction to the food and had to go to the hospital. I finally got home at 3am after a day at the track and hospital, slept 3 hours, washed the car and swapped wheels at 6am and made it in time for showcar load in by 8am:
Met up with SpecR and a few others from FB groups and Insta.
99 BDP RS
Great photos! Sorry to hear about the allergic reaction, but glad to see you pulled through!
Discussion Starter #1,472
Discussion Starter #1,474 (Edited)
I've been holding off on getting a real AOS for years but i finally bit the bullet. I installed a Crawford v2 AOS that was made for the GD wrx with a TMIC. I had to make a custom bracket to make it fit to keep the AC and strut tower bar. The only problems I had were that the breather hose on the crank case was brittle and was destroyed when I removed it and the passenger side valve cover breather was also rock hard. So I ordered new ones online.
Discussion Starter #1,478
Got my snail all snuggled up with a PTP STi fitment turbo blanket
I installed the Perrin heat shield on top of the blanket
Discussion Starter #1,480
Since we're all on lock down and the car isn't doing any events and 3 of the shocks are leaking, I'm removing the coilovers to be sent back to KW to be rebuilt.
I sent out the shocks and cleaned up the spring hardware
