1 - 3 of 3 Posts
1999 Impreza R.S (Turb0)
Impreza Actual
2001 RS-T
I had to find what wire from the factory ECU was the power wire to the rear lights and ran that to the reverse sensor on the new manual trans.
I think I just probed the old auto harness pin by pin with a hot (12V) wire until the rears lit up.
The two sensors that should be there are the neutral switch and the other is the reverse sensor. I don't remember which is which. One wire needs to be grounded and the other needs to connect to the one that lights up when given 12V.
I have to do this again since my swap so post up what you find out, it's been a while!
1 - 3 of 3 Posts
