Ive been having problems with my RS not idling. And i keep getting the same 2 codes.
P1112 Atmospheric pressure sensor range/performance problem
and later P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
I was reading about it on nasioc, and they were saying their cars would not run or idle when they threw the P1112 code. They also said that the sensor is located on the ECU.
But i think our car have that pressure sensor mounted on the pass side strut tower?
Anyways today i have replaced the PCV valve, and replace the fuel filer. Still doing exactly the same thing...
Oh!! and when i plug in my check connectors the CEL starts blinking and i can hear relays turning on and off in the car.... and the radiator fans come on and off.
Scanner is not able to read codes when this is going on...
all of my threads about this...
http://www.rs25.com/forums/showthread.php?t=83425
http://www.rs25.com/forums/showthread.php?t=83293
http://www.rs25.com/forums/showthread.php?t=82856
Any thoughts. I heard it could be EGR but i have no clue where that is or what it looks like.
