1 - 4 of 4 Posts
picked up an Auto 01 impreza 2.5rs, and the only thing that is has wrong is a constant flashing "AT OIL TEMP" light as well as it shifting hard from 1st to 2nd gear. Smooth after.
It also displays the "CHECK ENGINE" light but I assume that is linked to the AT OIL TEMP light.
Any suggestions would be greatly appreciated, thanks!
Super Moderator
2000 RSTi
You need to go to a place that works on subarus and get the codes read.
  • Like
Reactions: stalkergc
2000 RS Coupe
Do you have some sort of an automatic transmission cooler on your vehicle? Is this constant, flashing, "... AT OIL TEMP" light a specific automatic transmission light or are you just referring to the oil indicator icon that lights up on the dash?
One of the solinoifd are bad on your AT easy fix, Jack up the car drop the AT pan grab a good tester that you can put power to any thing, and put power to all 4 solenoids one at a time the one that don't click is the bad one
1 - 4 of 4 Posts
