FYI - CE light info
I got an e-mail from Random Technology today:
The alleged problem with low converter efficiency that triggers a Check Engine light isn't real. The OBD II system uses exhaust gas oxygen content to gauge converter efficiency. That's like using fuel pressure to monitor fuel flow. The assumption is that a given pressure in a line of a given diameter will flow a specific volume. However, if there's a restriction in the line, volume will be severely limited, in spite of system pressure.
With the OBD II system, the assumption is that oxygen content behind the converter will be substantially more consistent than content in front of the converter. And that's true when you have a restrictive converter that causes exhaust gases to back up in front of it. But when you increase flow capacity, the residual oxygen content behind the converter is not as consistent, so the PCM erroneously thinks converter efficiency has deteriorated. In spite of the fact that the system "thinks" converter efficiency is below the acceptable threshold, the converter is doing its job and the vehicle will pass an emissions test.
As for a fix, we're experimenting with different chemistry. There is no official specification for an OBD II-compliant converter.) As for existing vehicles with Check Engine light problems, the easiest fix is a "spoof" which incorporates two resistors in the rear oxygen sensor wiring. I have a wiring diagram if anyone would like to experiment and if we can find connectors, we'll make up plug-in units.
End quote.
To reply to Dave, if you want to help out, go here:
http://www.randomtechnology.com/contact.html
and use the e-mail at the bottom to send a message.
Peaty
