Installed pics? :banana:upgraded the intercooler -
Once the second polar vortex leaves wisconsin I will go outside and wrench. Tired of doing all these mods in -10 weather heh. However the hp gain from the cold weather is 4 wheel spinning fun!Installed pics? :banana:
edit: here is the fix - Top Mount Intercooler Y-Pipe Kit - Subaru - GrimmSpeed![]()
This is rather annoying :-/ now the ypipe is too short that i got. Going to have to extend it with some metal tube. Also the bypass valve for the intercooler has a different od than the bypass tube it needs to connect to.
so many little things...
Fixed my needle issue. turns out they were in the wrong start position. I turned the car to the on position and manually moved them back to 0. Everything has checked out so far speed and rpm.here is a video - after the needles move to this position they stay there. - Jdm gauge cluster issues - YouTube
Had to cut and weld a plate on the tmic to get it to fit properly. Yeah there was a lot more work than just a y-pipeLooks sick man. Other than getting the right "Y" pipe, any fitment problems? Great write up by the way
