441 - 457 of 457 Posts
1998, RS, Rally Blue 2.0 EJ20K
Discussion Starter #441
I got a lot of content to upload on the swapped forester here is the result today :D
#autoventuresLLC did the wiring - jeff is a great guy and has been around forawhile in the vw vanagon scene. He knows his stuff! not only that he will make sure you are taken care of. He does not quit
2005 ez30 swapped forester - first drive - YouTube
Discussion Starter #444
Exhaust went on yesterday
Coolant overflow tank is going to be mounted in front of the battery to get rid of the old plastic one.
Discussion Starter #449
RS update - Fuel system and new injectors .. then more boost (currently 32psi)
boost goal was around 40psi - should put me at the power level that is respectable :):crazy:
1995 EZ30 Coupe
boost goal was around 40psi - should put me at the power level that is respectable.
:eek:mg:
Dude... Respectable is an understatement...
This thing is gonna be nuts! Glad to have an update on the RS!
:projectsti.com:
Discussion Starter #451
:eek:mg:
:projectsti.com:
I want to pull the heads and fire/oring it and upgrade to 14mm head bolts :-/
but right now I just want to see if this setup can handle it. My guess after we get the fuel sorted it will be axle busting time.
Discussion Starter #453
I don't know where else to complain but the new format is terrible. Dark mode is a bit better but the layout and design are simply fucking awful (please have a style option for rs25 classic)
