wow sounds like my car
*high-five for morons & wiring*
he actually moved the coil pack (so only 2 of the wires I bought reach one side) and drilled a hold in the middle of the intake manifold and plopped my MAP sensor in there.
I have actually discovered the other day that it was out and hanging over the side of the manifold...how it happened exactly I dunno, but he really shoulda bolted it down or something...now I gotta buy sealant.
I'm on the path of replacing all the common sensors (both O2, Knock sensor to name a few), as well as replacing the entire manifold.
My IAC (Idle Air Control) valve/sensor whatever it is, isn't even connected to anything, so I Idle like crap.
The guy I bought it off of did his own swap w/ a JDM ej25d, had no clue what he was doing, so he sold the car. Of course I had no idea of the vastness of its issues at the time.
Have you checked to see if he might of swapped it? He could of done the same thing.
Now we can be mysterious adventure buddies!
I may be under an influence, so I apologize for ranting.
:banana:
