1 - 4 of 4 Posts
air intake with turbo setup
i was just wondering what air intakes you guys are using for your turbo RS setups. im beginning to piece together a turbo kit and just want to know what eveyone is running. this is hard.. but fun.
I'm just using a K&N filter. I pulled it off the intake on my brothers Civic before he sold it and it works fine.
Graham
2001 2.5RS
All you need really is a tube and a filter over it. You can vent the crank case vents into atmosphere with filters over them. Or you can use a build a custom tube with the small inlets welded into them for the three crankcase vents. If you have an aftermarket CAI the cut it and weld three inlets into it. Shold only cost you about $30?? for the weld job.
-Rich
I had a custom intake made for mine with three crankcase inlets on it, all aluminium.
You can see them if you go to the link:
www.pbase.com/graham222
Graham
1 - 4 of 4 Posts
