Advice on road trip / precaution (need help)
329 Views 5 Replies 5 Participants Last post by  impreza_GC8
Hey guys so recently swapped my 99rs with a ej205 built with forged internals and a vf48 turbo, stock heads. I have a 05 sti tranny swap but have not had the time and will not have the time for at least 4 months. My car will be back from tuning soon. So I’m about to go on a road trip Vancouver to Calgary and back (930km each way). I was wondering what you guys thought about taking the Subie for the trip. What I’m worrying about is the 5 speed, there’s no real issues with it except for a little synchro wear in gear 2 and 4. Do you guys think this an ok risk to take i will be doing my best to stay out of boost when shifting.
1 - 6 of 6 Posts
Drive it like a glass house and you'll probably be fine.
  • Like
Reactions: 1
So...I'll risk ridicule. Couldn't you just:
1. Have the tuner give you a WG tune (or whatever low boost is)
2. Run WG boost by a simple vac line re-route
And pretty sure that unless you're somehow avoiding all the mountain ranges (and their passes) on TC-1 staying out of boost will be....a challenge.
Reference> My '98 Forester NA-T has 255K on the original 5-speed and has seen 200-250HP w/out issue. (I don't launch it...never ever.)
  • Like
Reactions: 1
Youll be fine, i regilarly did 5+hr drives in my swapped car. I took a RS with 280k miles on it across the US, and Id drive it back too.
  • Like
Reactions: 2
Don't launch 1st gear and dont fuck up real bad on your shifts into 2nd and 4th gear and it'll be just fine with no surprises.
  • Like
Reactions: 1
You’ll be fine highway miles. Even if you did get crazy and blow a gear the other gears should still work. My experience blowing 5 speeds is they strip the teeth in whatever gear you blow and you can still use the other gears.
1 - 6 of 6 Posts
