1 - 11 of 11 Posts
'06 LGT
Well yesterday when attempting to replace the rear wheel studs in my '01 Impreza, I broke the ABS ring in the rear hub.
How do I replace this and how do I ask for it at the dealer. I.E. what is it called.
Thanks for the help.
2000 Imp 5 door Sport
it should just un bolt realy easly. as far as the dealer i might have the part number at home i will be back sunday night. ill check.
Junk yard would be a pain to get it cause of where it is located
'06 LGT
Discussion Starter #4
And how would I go about replacing this ABS tone ring, I would imagine I would have to remove the knuckel, have the bearing pressed out and all that jazz. Anyone willing to help or have any information regarding replacing this thing.
got your part number
26750AA014 and i looks to be about 90ish for it
they call it an ABS rotor
your going to have to
pull axle
push out the center hub thing that you wheel studs are on
replace that ring and put new seals in around the wheel bearings
then press it back togeather
that going to be alot of work
RBP 1998 2.5RS sold
Are these nessesary? Do you have to have them in? I know without them you'll have no ABS. But can I run without one?
I've been driving around with two broken front abs rings and its fine. Just tie the ring down to your hub or cut it off or it will rattle around while driving.
1 - 11 of 11 Posts
