1 - 14 of 14 Posts
06 Lexus Rx400h
just get wrx or sti ones and you'll be fine.. you dont need anything crazy..
99 Impreza RS rally blue pearl
I'm not too sure about newer Impreza's but I think you would be fine with the stock injectors as long as you dont go above 7psi, 5 should be just fine.
'00 RS w/ 05 STi swap
im at 9psi on my stock ones with emanage ultimate and im fine (rugged edge of needing new injectors) so 6 psi is easily fine with stock
Discussion Starter · #9 ·
ok thanks alot, oh and another question. i heard that the uppipe doesnt clear the cross member and that you would need a wrx/sti cross member, or you could use a one inch spacer between the headers and the uppipe, would that work?
2005 Subaru Impreza RS 5MT
This has been done, you need to search better.
New crossmember or notch your crossmember. A replacement is the better idea.
That's one of those things you have to go figure out yourself. The crossmember is not designed to remain rigid when you take a chunk out of it. You have to reinforce it afterwards. Just buy a turbo crossmember.
1 - 14 of 14 Posts
