So if I swap the wires at the motor the window goes up when u press down on the passenger switch so I know the motor works both ways. When I changed the passenger switch with a brand new unit it didn't change what was already happening with the other switch. I also changed the relay yesterday with a new unit. I tested the sbf6 and the fuse is fine. What I'm not sure of is if I remove the fuse it reads 12 volts on one side, the other side should be dead of ppwer....But it reads 2.something volts, could it be a short or is there something wrong with the driver switch? Also from the driver side I get no use of the passenger window at all, it will only go down when wired correctly from the passenger window switch. And no lol, the lock button isn't depressed.
